Question about Insteon i3 and ISY994
I am in the process of replacing some of my older Insteon outlets with the newer i3 series. Do they function the same as the older dual band dimmer outlets? Is the ISY programming the same? Any information would be most helpful.
Regards,
Tom
Solved by tlightne
It is my understanding the 994 does not support i3 devices. I am sure someone will correct me if I am not correct.
You're correct. Isy does not support i3 devices. Only polisy and eisy on the latest firmware
Edited by lilyoyo1
I got a couple of the newer I3 outlets. I3 do not work with the 994 but I had just upgraded to EISY (mine are at 5.7.0), so no issue for me.
There are several key differences between the I3 outlets and the older dual band dimmer outlet (which I also have installed - 2472D v44).
First and foremost, the I3 is not a dimmer - only on/off. The good news is that this means you don't need that magnet thing on the plug to use the outlet. The bad news might be that it isn't a dimmer - but I am using it for a fan so didn't matter to me.
Second, Both the top and bottom outlets are controllable - not just the top one.
Third, the I3 load sensing, is supposed to be able to trigger an event to control other devices when you manually turn on/off the device that is plugged into the outlet, but I have not figured out how to use that yet.
Programming wise, it is the same other than not being a dimmer and having two devices in one. I have one outlet set to turn on when I turn on a wall switch for a bathroom fan. Also use a programmed timer to turn it off.
I'm keeping the old dimmer outlet because it works well in the nightstand to dim the light and the other outlet is used for charging a smartphone so doesn't need to be switched.
Andy
Andy
On the Insteon side of things, they had a separate dual relay outlet and a single dimmable outlet (that you're referring to).
The i3 version simply replaces the relay version. Hopefully they'll release a dimmable version in the future.
Thanks for everyones input. I guess I'll be upgrading to an EISY soon.
Regards,
Tom
Oh Thanks for clarifying, I never had one of those dual relay outlets.
