Are Micro-Brite CCFL bulbs bad for Insteon network?
I was curious if anyone knows if these CCFL's cause any type of interference in the Insteon network?
do standard CFL bulbs?
thanks,
someguy
My experience is yes they cause interference, usually thing turn on fine but will not turn off. Same issue as X10
I had to install some filters in the cans of my recessed lights where I had several of them.
:cry:
I had eight MicroBrite MB-800DP 8 watt CCFL bulbs in use.
5 where on ApplianceLincs and 3 on a SwitchLinc Relay; with no problems controlling them. My XTBM X10 meter shows very little noise coming from them. This meter can read noise up to .99 volts in the X10 [insteon isn't that far away] frequency range. Though there was no power line noise. They did radiate lots of RF noise right around both the X10 and Insteon Power Line Signal Frequency. I guess they could get noise into a modules electronics. In some rare setups.
I don't have any data on the larger wattage MicroBrites that are now being sold.
I do have a reliability problem with them. 5 died in less than a year. Would light when cold. As they warmed up would blink on and off and then when fully hot. Would run for the rest of the night. I had spares so the total in use is now 7. One place in the home just needed more light than the 8 watts could supply so it was replaced with a larger CFL.
Now you want to see a real noise maker. An EarthLED EvoluxS. 13 Watt LED bulb. Drives my XTBM over the max reading so I actually don't know how much noise it is spewing out.
      37.5k
      375k
