Hikvision NVR camera widget
I’m trying to add my cameras to ud mobile but clearly doing something wrong
rtsp://username:password@ipaddress:port/Streaming/Channels/101
Ipaddress - I’m using the internal NIC IPv4 address, couldn’t see anything else
port - using 554 which shows as the rtsp port
once I get the first working I’m planning on using 102, 103 etc for the different cameras
any suggestions would be helpful
Solved by bgrubb1
Is this part a requirement of your camera to connect via rtsp?
For my Foscam cameras, after port, I have:
/videoMain
You need to check the rtsp format required for your camera.
Try using the command in something like VLC Media Player to see if you have the correct format.
Have you checked out this video on youtube.
Some settings on camera side need to be changed.
if as you say, its a NVR and connected to a DVR you will need to adress the DVR
In my case I had to enable on the DVR then...
rtsp://username:password@DVR.IP.Address:554/chID=1&streamType=main&lnk-Type=tcp
Also notice  Linux is case sensitive
Edited by bgrubb1
