thermostats other than nuheat
Saw this node server and took a look at the hardware it supports.
It looks like the hardware is exactly like my Schluter & Microline controllers for my heated floors.
Wondering if, with some small mods this node server can work with those as well.
The apple apps are almost exactly the same as well.  Dirt-heat / Microline
Thoughts?
They're probably either using the same hardware/API or the API is different for each company that rebranded the hardware.  I have no information on any of these, including the nuheat as I didn't write the node server.
The only real way to know is to get the API from Schluter & Microline or to just try it.
I just swapped out my Schluter Thermostat for a NuHeat and it's been working fine for over 3 years.  A bit more expensive than a node server, but if there isn't one. ....
Edited by glarsen
