Geofence to trigger Blink cameras when leaving
andrew77
I love the geofence stuff. When I come home the lights come on inside and out.
Is there a way to arm the Blink cameras when I leave the house?
Not a big deal if not. Just asking
  • 3 months later...
Any answer to this?  I’d like to do the same thing.  I use geofencing already and have variables set up based on who is home so logically it should be easy to arm cameras based on these variables.  I do not have the Blink node yet.  Is doing something like this possible?
I do not have Blink cameras so am unfamiliar with what capabilities with the Plug-in are available. However, if you do have the plug-in and if you can arm it via the AC, through a  program, then its very easy to tie you geofence into this.
Example:
-Geofence turns a variable from 0 to 1 when you leave.
-program IF monitors the geofence variable and the THEN arms the blink cameras
-ELSE unarm the blink.
"program IF monitors the geofence variable and the THEN arms the blink cameras"
Thanks, Yes I have geofencing set up and it works fine.  Its the THEN arms the blink cameras part I'm asking about.  The only hook I have is alarm_control_panel.blink_home  in Home Assistant.  I am trying to figure how to call that from EISY.
      37.8k
      377.8k
