Sonos server 3.01 no longer working
landolfi
For some reason the free Sonos server no longer works on 3.2.16. Is this a known issue? After installation, the message appears:
"No speakers found. Make sure they are powered on and try Disover again."
The Sonos app and Home Assistant see the speakers, just not the Sonos node server. I've tried re-installing as well as deleting and re-installing. There are no nodes.
I could have sworn that the devices were discovered automatically in the past even though they were idle, but they did eventually show up after each one played audio.
  • 4 weeks later...
I implemented a vlan and lost discover.  I modified the sonos-poly.py to have functionality similar to the harmony controller.  I'm going to ask if it can be put in to the production instance.  Essentially you add custom config values using format of:
key = sonos_(some_name_you_want_to_use)
value = {"name": "(name you want to use)", "host": "xxx.xxx.xxx.xxx"}
I've attached the file in case you want to use it.   YOu have to copy to your node server directory
/var/polyglot/pg3/ns/{nodeserver directory} as sonos-poly.py
sonos-poly-mod.py
      37.8k
      377.5k
