Mini Remote as a "responder"
Am I correct on this...
a RemoteLinc 2 (Mini Remote) can NOT have membership in scenes as a Responder.
The Mini Remote is not "awake" to respond to commands from other controlling devices in the same scene.  As a result, controlling inputs by other scene members will cause the Mini Remote toggle sequence to go out of sync.
Tuchman: thanks for responding.
still trying to fully understand the Universal Devices Administration Console...
M/R (8button). added several buttons as a controller to a scene.  when a button is highlighted in admin --  the Membership lists controllers and responders.  Do you think this is just a programming oversight.  and if so, can it be noted?  was a bit confusing at first.
The battery operated remote can only be added to a scene as a controller.
In the admin console you'll notice that's there's no relationship associated to the "is responder to". This is by design. If you list a device that is capable of being both a controller and a responder, then the associations would show up.
Edited by Techman
