dbroere Posted November 15, 2023 Share Posted November 15, 2023 Am I correct on this... a RemoteLinc 2 (Mini Remote) can NOT have membership in scenes as a Responder. The Mini Remote is not "awake" to respond to commands from other controlling devices in the same scene. As a result, controlling inputs by other scene members will cause the Mini Remote toggle sequence to go out of sync. Link to comment Share on other sites More sharing options...
Techman Posted November 15, 2023 Share Posted November 15, 2023 Correct. It can only be a controller. It is unable to "respond". 1 Link to comment Share on other sites More sharing options...
dbroere Posted November 16, 2023 Author Share Posted November 16, 2023 Tuchman: thanks for responding. still trying to fully understand the Universal Devices Administration Console... M/R (8button). added several buttons as a controller to a scene. when a button is highlighted in admin -- the Membership lists controllers and responders. Do you think this is just a programming oversight. and if so, can it be noted? was a bit confusing at first. Link to comment Share on other sites More sharing options...
Techman Posted November 16, 2023 Share Posted November 16, 2023 (edited) The battery operated remote can only be added to a scene as a controller. In the admin console you'll notice that's there's no relationship associated to the "is responder to". This is by design. If you list a device that is capable of being both a controller and a responder, then the associations would show up. Edited November 16, 2023 by Techman Link to comment Share on other sites More sharing options...
