Upgraded java now the console will not launch
I upgraded from Java 8 to OpenJava 17. There is no javaws.exe file in this version.
How do I get the console to startup? I don't want to have the old version installed.
Solved by Techman
The new versions do not have a control panel, so you can't clear the cache.
Other programs require newer versions of Java.
So, my isy console is basically dead? ☹️
The version of java you're running is open source, so there could be security issues.
You might be able to install java 8 in a virtual machine, or you can use UD Mobile which doesn't require java.
You must have read my mind. I have a Win10 VM running on Proxmox where I installed jre 8 and that works.
Interesting, I found a program called IcedTea-Web 1.8.8.  It did not work with start.jnpl. Did not find Iox. However, with admin.jnpl, it worked and brought me to the login. So now I can use Win11 or my VM.
