Sonos Node Server can not Load Profile to Polisy Isy
The Sonos node server is running in PG3 but will not transfer to the ISY on Polisy. I had it working once but had to uninstall it to get z wave working. I didn't get it written down what I did then.
PG3 Version 3.1.23
Status: Connected
Frontend Version: 3.1.23
IoX Version: 5.7.1   Disconnected
Uptime: 3 Day(s) 6 Hour(s) 34 Minute(s) 54 Second(s)
(c) 2023 UDI
Getting Started
What am I missing this time?
Clicking "load Profile" does not install it to a node server slot in the Admin console Node Servers drop down menu.
Edited by Flex
Additional info added
Solved by DennisC
That shouldn't be disconnected. Try rebooting or power cycling Polisy.
Found out I had the wrong password for the ISY in PG3. Once I corrected that, it then connected. But clicking "load Profile" still does not install it to a node server slot in the Admin console Node Servers drop down menu.
Go to the configuration tab in the plugin and follow the directions for entering configuration info. Make sure admin console is closed, restart plugin, then start admin console.
I tried that and it did not show up in the Admin console Node Servers drop down menu.
Does the nodes show up in the admin console?
You shouldn't need to be in that window. If there are no nodes in the admin console and you completed the configuration correctly, then the plugin didn't install correctly.
Check the plugin log for errors and if nothing shows up reinstall the plugin in the same slot from the Purchases tab of PG3.
I haven't used this plugin so I don't know the particular's of the configuration screen, but everything must be correct there.
I am getting these errors;
12/3/2023, 16:33:36 [pg3] error: drivers = [{"driver":"GV1","value":0,"uom":56},{"driver":"GV2","value":0,"uom":56},{"driver":"SVOL","value":"9","uom":51},{"driver":"ST","value":"2","uom":25}]
12/3/2023, 16:33:36 [pg3] error: [00:0d:b9:53:2f:60_5] caafd2b5862014/addnode add driver error: UNIQUE constraint failed: driver.uuid, driver.profileNum, driver.address, driver.driver
12/3/2023, 16:33:36 [pg3] error: drivers = [{"driver":"GV1","value":0,"uom":56},{"driver":"GV2","value":0,"uom":56},{"driver":"SVOL","value":"8","uom":51},{"driver":"ST","value":"0","uom":25}]
12/3/2023, 16:33:36 [pg3] error: [00:0d:b9:53:2f:60_5] caafd6d1482014/addnode add driver error: UNIQUE constraint failed: driver.uuid, driver.profileNum, driver.address, driver.driver
12/3/2023, 16:34:41 [pg3] info: Starting installed and enabled NodeServers...
12/3/2023, 16:34:41 [pg3] info: startNs:: Sonos
12/3/2023, 16:34:41 [pg3] warn: Sonos validation checks returned :: Already running.
What do these errors mean?
Reinstalling the plugin in the same slot from the purchases tab of PG3, worked.
