Release Info
Decided to make a new thread to add info on new releases rather than create anew one for each new release
Info also exists in release notes
0.9.87 - Added more info for TH sensor alarms (and fixed bug).  Improved node stare for multiOutput device if the device is off-line during start
  • 3 months later...
Version 1.0.3 available
  • Added support for schedules.  My main use is to disable/enable schedules but one can also create schedules dynamically.   Schedules will run off-line so works if internet is down
  • Improved delay setup input - Both can be set in same operation as enabling them.  (I may remove the old version as it takes extra screen space, but it will require programs to be updated.  Delays also run off-line
  • Added support for the new switch with 2 extra buttons and second programming of delays - make sure to update firmware.  Buttons works like the FOB/Remote - only tested YS5708
  • Added support for Alerts in power sensing outlets (trigger on high power, low power etc)
  • Added preliminary support for watermeter (there is no official API yet)
  • Fixed few bugs relating to on-line state
  • Moved to different MQTT method - seems to match closer what YoLink uses for counting API calls
Version 1.0.6 is available
Mostly a fix for off-line reporting for sensors
Latest version is 1.0.7 after another minor bug fix
  • 3 weeks later...
Latest version is 1.0.8 after another minor bug fix for the water meter controller
  • 4 weeks later...
Updated to version 1.0.9
Minor fix to improve cases where tokens are lost - not easy to test (and it should not happen often)
  • 5 weeks later...
Updated version to 1.1.0.
Supports python 3.11 which  the next release of PG3x requires
Will still work on PG3 but not sure how long it is possible given PG3 runs older version of python.  It is suggested to upgrade to PG3x (testing will be on PG3x going forward)
No other changes introduced
Hi... it's not clear on the order of next steps. Should I go head and upgrade the yolink plugin now, prior to the next PG3x release, even though the current PG3x release doesn't support python 3.11?
Edited by paulbates
You can update now - it should work with the current release but you can also wait.  My understanding is the bigger will get updated automatically when the new PG3x released
I personally would wait
Thanks, that was the question
