Create program for KPL button to match status of light
I have created a program that the status KPL button (F) will turn on if a bedroom1 light is on and off if bedroom1 light is is off.
If status of bedroom1 light is on
then set KPL button (F) to on
else set KPL button (F) to off.
The problem is when I add the second bedroom (bedroom2) with the or statement bedroom1 will turn on as well, because KPL button (F) is a controller.
I want KPL button (F) to be a controller so I can turn off/on the bedrooms.
Hi Moshe,
How do the bedroom lights turn on/off? i.e. do they have their own switch. If so, why not use a scene where all of them (including your KPL button) are controllers?
In any case, you want something like this
    Status bedroom 1 is not off
Or  Status bedroom 2 is not off
Or  Status bedroom 3 is not off
    Set the-scene-containing-your-kpl On
And, you would want the opposite for Off
      Status bedroom 1 is off
AND  Status bedroom 2 is off
AND  Status bedroom 3 is off
    Set  Set the-scene-containing-your-kpl Off
Hi Michel -
If I make a scene and make all devices controllers then all of the bedrooms contol each other. I do not want the bedroom switchlinks to contol each other, just the KPL button.
I will try your program.
Could I just use the else statment in the first program to set KPL Button (F) to off.
Michel -
By using your program, once one of the bedroom lights is on the KPL (controller) will turn on causing the other bedrooms to turn on, correct.
If I do not set the KPL as a controller will I still be able to turn off/on the bedroom lights from the KPL button.
