UD Mobil does not work in my Wifi Network
UD Mobile does not work once I am connected to my Wi-Fi. When I leave the house outside of my network it works fine. It was also working within my network a few weeks ago.
Any ideas on how to regain access to my UD Mobile while I'm in my network?
Solved by Javi
Likely due to Local IP Address Changed.
If you Added a WiFi network in Settings Tab > Systems >  Your System > Local Connection Settings (expanded) > System Network Relations. Then the app is on this network it will attempt a direct local connection.
So either the IP entered into the app must be reserved on your router or remove the WiFi Network from Local Connection Settings.
