Pushover Notify Server Question
Solved by Kentinada
More on Q3 above:  When I press the Send Sys Custom button, the last status goes to False and the device has a red ! on it in the AC.   What is it hiccuping on? Screenshot2023-12-21at9_19_38AM.thumb.png.cd5d965758e17dbd14778ac1b5741cd6.png
Ok so the work-around is use the Send Sys Custom with Params command (highlighted in bold below.) This works where the Send Sys Custom command does not.
Notification OnOff-9.1 On-Off Module - [ID 0017][Parent 0001]
        'Office / OnOff-9.1 On-Off Module' Status is On
        Set 'Office / OnOff-9.1 On-Off Module' Beep
        Set 'Notification Controller / Service Pushover UDEISYPO' Device KBM_iPhone
        Set 'Notification Controller / Service Pushover UDEISYPO' Send Sys Custom With Params To KBM_iPhone Priority=Normal Format=None Sound=Pushover (default) Retry=30 Expire=60 Content 4 Notification ID (ID=4)
        Set 'Notification Controller / Service Pushover UDEISYPO' Message Test2
        Set 'Notification Controller / Service Pushover UDEISYPO' Send Message
You only need the bold line, you don't need the other 3 lines to send a message.
@Jimbo.Automates Jim I understand that.  But I have been digging into this so much, I'm trying to understand the various methods of getting a message out so that I might help others.  In the end, I'll pick one method and stick with that.  Thanks.
