Why does this code not work?
I think I have it correct.  The Wireless Tag motion senses motion and the light turns on.  All good to this point.  But the light does not turn off.  Why is the code wrong?   Thanks for the advice.
Utility Room Motion
        'Wireless Tags / Utility Room Sensor' Event State is Detected Movement
        Set 'Basement / Utility Room' On
        Wait  15 minutes
        Set 'Basement / Utility Room' Off
Solved by Goose66
If the tag turns off before 15 minutes, the program stops running.. is likely the cause.
Try putting the actions in a separate program, and change the 'then' of the current program to run the new program. The new program should have no 'if' statement
Here's a more elegant one program version that came up on my drive back home from family Christmas
 Wait 15 minutes
 Wait 15 minutes
Thanks for the thoughts.  I will give the latter idea a try.  Does it matter at all if the tag continually senses motion and keeps sending an on signal to the switch?  Would use of a variable program help here?
Edited by UD2)17rrh
Cleanest solution here (and just about all other instances with motion/presence triggering events and timed activities) is the two program solution:
First program: Utility Room Motion (Enabled)
        Run Program 'Utility Room Lights on Motion' (Then Path)
Second program: Utility Room Lights on Motion (Disabled)
   - No Conditions -
        Wait  15 minutes
When the Wireless tag sends movement, the first program starts the second program, and the second program turns on the lights, starts the timer, and turns off the lights when the timer expires. Subsequent motion from the Wireless tag turns the lights on again and resets the timer. 15 minutes after the last motion detected, the lights turn off.
An advantage to this structure is that it works whether or not your Wireless Tag (or other motion detector) sends a DOF (No Motion) command after some delay.
Edited by Goose66
To further explain this, read this wiki. https://wiki.universal-devices.com/ISY-99i/ISY-26_INSTEON:Scope,_Precedence_and_Execution_Order#Statement_Execution_Order
Whenever a WAIT is encountered, the IF is re-evaluated. In your program case, the if then becomes false so the program runs the else and never gets to the last command.
@Goose66 is indeed the cleanest and most strait-forward approach and one I use all the time.
Edited by dbwarner5
fixed error.. "encountered replaced completed
Thank-you!
Thank-you and bookmarked the how-to guide.  Thanks for sending.
