Evolux by Lloyds bulb
Hi guys,
I received one of those Amazon bulbs for Christmas and was wondering if the ISY can control it or do I have to make a routine with Alexa.
I would just like it to shut off when I give the verbal command for my night scene
Edited by andrew77
Solved by dbwarner5
What is the verbal command for your night scene doing? Is it simply turning off /on a scene? If so, the easiest thing is like you suggested, create an Alexa routine that first turns off/on the same scene you were using and then turns off the amazon bulb. Pretty simple.
Edited by dbwarner5
Of course. I had it in my mind I'd have to change the spoken word to trigger the scene. Duh, I just changed the old scene and the new Alexa trigger is the old trigger word.
Thank you for giving my head a shake
(I don't see where I can select your post as the answer, maybe that's not my call)
Edited by andrew77
Do you see this green box in my post? be sure to be signed in. Screenshot2023-12-30at1_09_33PM.jpg.6e619a8bb18498a811edd1e001614d2e.jpg
Edited by dbwarner5
I don't see that. I only see this.
Maybe I'm still too much of a noob on the forum to wield such power.
haha
interesting. I wonder what makes it appear. If I go to threads that I started, it usually there.. maybe you have to first Like the post?
