Schlage Plugin Error
Why am I getting this error?
Solved by Goose66
Believe so. The log shows polling.  This error happens randomly.
Appears to be periodic REST call failure that I’m not handling gracefully. Since it’s an authorization error it’s also posting the notification that’s never getting cleared.
if you can turn on debug logging and capture more info, I can release a new version that ignores the periodic error.
Will do tomorrow.
Attached is the debug log and a clip of the error section for your review.
debug.log
Is this error going to be resolved.  Have not heard anything since submitting the debug log.
23 minutes ago, tlightne said:
@TUhl01  Did you send the log to the developer?? That is the best way to make sure they get it...
The information is included in this thread. Look above.
In the post, he was the person that asked for this.
I've had  put in a note to fix it in next release. But as I mentioned, it is a non-fatal connection error very infrequently returned from the Schlage API the plugin uses, and the data is updated on the next poll. But it adds the notification when the error occurs. So even though it's logged as a warning and the plugin recovers on the next poll, the notification just hangs out until you clear it. Shouldn't cause any issues in the operation of the plugin.
Thanks - Topic Closed
