Ring Stopped Working Today
My Ring StickUp Motion Camera which was working fine has quit working or at least the node server/plugin has quit.  I did upgrade to 5.8.0 firmware today so I'm not sure if that is related or not.  When I test the Ring device from the AC, it fails. See Event viewer log attached. Also attaching the dashboard view of the Ring Node Server and everything there looks OK I think.  Any ideas where to start?
Solved by Kentinada
It is something on the EISY/Node Server side.  I enabled notifications in the Ring app and it works fine.  But no motion message was sent from my EISY.   Very simple notification program:
Front Door Motion - [ID 001D][Parent 001C]
        '07-Front Porch / Ring / Front Door (Motion)' is switched Motion
        // This is a Message sent to UD Mobile
        Set 'Notification Controller / UD Mobile' Send Message To Kent Sound 'default' Content 9 Notification ID (ID=9)
I get nothing.
I re-installed the Node Server and it is once again working.  Not sure if this was related to the 5.8.0 update or not but at least it's working again.
@Geddy Thanks for the idea.  The re-install seems to have worked. I did check the portal remote connection just now too and it's all good.  Thanks!
