Elk RP "turn on FOR x minutes" - not working via I
simonw
Greetings
I am experimenting with using my Elk system to control Insteon lighting via the ISY. Basically it works fine, I can control all the Insteon devices. Every switch in the house is now Insteon, but I rely on wired occupancy and motion sensors connected to the Elk.
In Elk RP there is a useful-looking programming construct "turn on device for x minutes". Right now this command only seems to turn on my Insteon lights, but never turns them off.
Am I missing a trick? If it really does not work, please put this functionality on the request list for the upcoming and much desired Elk module.
Thanks for your help,
Simon
Hi Simon,
As WayneW mentioned the lighting timer issue has been addressed by ELK and a new firmware version will be released soon. ELK-M1G firmware 5.2.0 and 4.6.0.
In the meantime if you need the light(s) to automatically turn off after a trigger, you can use the timer associated with an unused output to turn off the light.
Example:
WHENEVER MOTION DETECTOR (Zn X) BECOMES NOT SECURE
THEN TURN Light X ON
THEN TURN OUTPUT 101 ON FOR X Minutes
WHENEVER OUTPUT 101 TURNS OFF
THEN TURN Light X OFF
Regards,
Don Lamb
ELK Products
  • 6 months later...
Whenever I turn on the light for 5 minutes, if someone turns it off before the 5 minutes completes it will automaticaly turn back on at the end of the 5 minutes. Is this being worked on in the current future release?
My experience is the same. I have some entry-way lighting that turns on for five minutes when a door is opened that is often turned off manually before the timer expires. After five minutes, the lights turn back on!
It seems the Elk is toggling the switch rather than just sending an "OFF" command.
A-ha! ... thanks for bringing this up, it explains a lot of the weird lighting behavior I've seen but couldn't explain.
II suppose it's back to using an Elk rule to turn a lights off if the corresponding output has gone off, like we had to do before the "turn on for x minutes" statement was "working".
A real fix from Elk would be much appreciated.
Simon
