Stopped working
I installed this a couple of months ago and it worked great. I'm not quit sure when it stopped working as it only gets used maybe once a week. Could one of the recent updates be the cause? I uninstalled it and installed it into a different slot with no luck.
I'm getting this notice on the PG3 page:
Solved by Michel Kohanim
I did all that, even a couple of reboots. Now I get "Unable to open serial port /dev/pg3.noyito"
That fixed it. Thanks.
I really don't want to be "that guy" but I am at a loss here. Yesterday, I was getting Authentication Error while trying to log into  the PG3 homepage. I rebooted my eisy and then was able to log in normally. However, this plugin was not working after the reboot, so I followed the above steps to get it back working. After that, I got the Authentication Error while trying to log into PG3 again. Another reboot cleared it up, but then it became an unending cycle of the plugin not working, then working, not being able to get into PG3, and rebooting. So for now I have this plugin turned off and the USB cable to the relay disconnected and everything else is fine.
I can start a ticket if that would be a more proper channel for this issue.
