One Elk keypad missing from AC Condition / Control pull down choices
I have an elk system with a total of 16 devices shown under the Elk Area 1 nodeserver in the AC. One of those 16 devices, which is named "UP keypad 1" is not showing up in a AC program as a choice when I select Condition / Control . I have two keypads, and the other keypad, which is named "DN keypad 2"  is available as a choice. "UP keypad 1" is listed as a node in the PG3x elk node server details, and it is present in the AC under the Elk Area 1 nodeserver, but it is not a choice for an AC program when I select Condition / Control. At first I thought I must just be missing it in the list, but I have scrolled up and down and checked several times, and it is not there.
Solved by Jimbo.Automates
On 1/18/2024 at 9:19 AM, Jimbo.Automates said:
Sorry, I can't see how this could happen.  I'll try to look into it and get back to you.
Should I open a ticket? (perhaps an issue with AC and not with Elk nodeserver?)
13 minutes ago, Jimbo.Automates said:
Sorry for the delay I neglected to add this to my task list and forgot about it.
Does that keypad have a thermostat?  I have a profile entry for keypad and keypadT and looks like I never updated keypadT.
Jim,
The missing keypad does have a thermostat (It is an Elk M1-KP)
46 minutes ago, Jimbo.Automates said:
@wmcneil Released 3.10.12 which should fix this issue.  Please confirm since I don't have this keypad to test with.
I have installed 3.10.12 , and can confirm the previously missing keypad is now present....Different feature: I plan on testing the function button press detection, and if I come across any issues, I'll open a new thread....Thanks!
