How to get beyond "Failure to Set Up" with the Home Assistant UDI plugin?
Go to solution Solved by shbatm,
I have installed Home Assistant on a spare NUC and have just begun to learn HA in order to connect to sensors not supported in Polisy. I and am hoping to access my UDI Polisy v5.8 system via Home Assistant to make it all run seamlessly. (LOL)
I can install the plugin and connect to the Polisy.  I then see the HA query all of my devices but the setup then seems to fail with some missing "available nodes" in Home Assistant. Am I reading this correctly? Any ideas as to how to fix?
Here is my Home Assistant log:
2024-01-18 14:41:29.986 DEBUG (MainThread) [pyisy] ISY Response Received: /config
2024-01-18 14:41:30.020 INFO (MainThread) [pyisy] ISY Loaded Configuration
2024-01-18 14:41:30.022 DEBUG (MainThread) [pyisy] ISY Request: http://192.168.1.72:8080/rest/config
2024-01-18 14:41:30.027 DEBUG (MainThread) [pyisy] ISY Response Received: /config
2024-01-18 14:41:30.050 INFO (MainThread) [pyisy] ISY Loaded Configuration
2024-01-18 14:41:30.050 DEBUG (MainThread) [pyisy] Increasing available simultaneous connections
024-01-18 14:41:32.004 DEBUG (MainThread) [pyisy] Parsing group: S-All Dining Room [13825]
2024-01-18 14:41:32.005 DEBUG (MainThread) [pyisy] Parsing group: S-Dining Room [21083]
2024-01-18 14:41:32.006 DEBUG (MainThread) [pyisy] Parsing group: S-All-Office [338]
2024-01-18 14:41:32.007 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-H Special Lights Status [37129]
2024-01-18 14:41:32.007 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-C Kitchen Status [688]
2024-01-18 14:41:32.008 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-B Guest Rm Status [52360]
2024-01-18 14:41:32.008 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-1 Hall Status [27424]
2024-01-18 14:41:32.008 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-E Office Status [38353]
2024-01-18 14:41:32.009 DEBUG (MainThread) [pyisy] Parsing group: S-Christmas Lights [15887]
2024-01-18 14:41:32.009 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry ISY (192.168.1.72) for isy994
Traceback (most recent call last):
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 406, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/isy994/init.py”, line 104, in async_setup_entry
await isy.initialize()
File “/usr/local/lib/python3.11/site-packages/pyisy/isy.py”, line 143, in initialize
self.nodes = Nodes(self, xml=isy_setup_results[2])
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/init.py”, line 127, in init
self.parse(xml)
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/init.py”, line 461, in parse
Group(
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/group.py”, line 57, in init
self._update()
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/group.py”, line 101, in _update
valid_nodes = [
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/group.py”, line 105, in
self._nodes[node].status is not None
AttributeError: ‘Nodes’ object has no attribute ‘status’
Thanks in advance for any help!
Edited by gviliunas
Link to comment
This looks like something I've seen before that had to do with naming of a node/folder on the ISY side that pyisy didn't like.
Can you please visit http://192.168.1.72:8080/rest/nodes and http://192.168.1.72:8080/rest/status in a browser and send me the files saved as XML and I'll take a look? (assuming that's your Polisy ip from logs above)
Link to comment
Your "S-Christmas Lights" scene has a link to your "Leak Sensors" folder, I'm not sure how or if that's intentional, but my guess is that's whats causing it to choke:
<group flag="132" nodeDefId="InsteonDimmer">
  <address>15887</address>
  <name>S-Christmas Lights</name>
  <family>6</family>
  <hint>0.0.0.0</hint>
  <parent type="3">47955</parent>
  <deviceGroup>29</deviceGroup>
  <pnode>15887</pnode>
  <members>
    <link type="0">ZY076_1</link>
    <link type="0">ZY077_1</link>
    <link type="0">37 C7 69 1</link>
    <link type="0">35 53 E5 1</link>
    <link type="16">3D 7A 77 8</link>
    <link type="0">51393</link>
  </members>
</group>
<folder flag="0">
  <address>51393</address>
  <name>Leak Sensors</name>
  <family>13</family>
  <parent type="3">53032</parent>
</folder>
Edited by shbatm
  • Thanks 1
Link to comment
