Roomba discovery not working on PG3x?
Discovery on initial startup isn't working, and I've tested on both an eisy and a polisy, both with PG3x, seeing the same log entries.  Anybody run into anything similar?
2024-02-09 08:24:17,704 Thread-1   udi_interface      INFO     roomba-poly:start: Roomba node server starting
2024-02-09 08:24:17,772 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Connected with result code 0 (Success)
2024-02-09 08:24:17,774 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:60:46_24 -  MID: 2 Result: 0
2024-02-09 08:24:17,818 MQTT       udi_interface.interface INFO     interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,)
2024-02-09 08:24:17,893 MQTT       udi_interface.interface INFO     interface:_message: custom data response {'customparamsdoc': '<h3>Roomba robots are auto discovered</h3>\n\n<p>If no robots are configured when starting, the node server will start the discovery process.\nThis will look for Roomba devices on the network. For each device found, you will then have\nto manually put the Roomba in to a mode that allows the node server to query the authentication\ninformation from the device.  You will be prompted via a notice when this is required.</p>\n\n<p>The discovered Roomba deivces are then saved so that future starts can skip the discovery process.</p>\n\n<p>If you need to re-discover devices, use the "Discover" button in the UI to start the discovery\nprocess.  This will clear any exising devices and start from an empty list.</p>\n'}
2024-02-09 08:24:17,933 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = customparamsdoc
2024-02-09 08:24:18,014 Thread-3   udi_interface      INFO     roomba-poly:handleRobotData: Loading saved robots {'robots': {}}
2024-02-09 08:24:18,018 Thread-3   udi_interface      INFO     roomba-poly:handleRobotData: We have restored the saved robot list
2024-02-09 08:24:18,021 Thread-3   udi_interface      INFO     roomba-poly:handleRobotData: Finished with handleRobotData
2024-02-09 08:24:18,054 MQTT       udi_interface.interface INFO     interface:_message: Profile installation finished
2024-02-09 08:24:18,125 Thread-5   udi_interface      INFO     roomba-poly:handleConfigDone: No saved robots...
2024-02-09 08:24:18,126 Thread-5   udi_interface      INFO     roomba-poly:discover: Attempting to discover Roombas
2024-02-09 08:24:18,129 Thread-5   udi_interface      INFO     roomba-poly:_get_response: Comparing irobotmcs with irobotmcs
2024-02-09 08:24:25,142 Thread-5   udi_interface      ERROR    roomba-poly:_get_response: Socket timeout while waiting for response
2024-02-09 08:24:26,207 Thread-5   udi_interface      INFO     roomba-poly:_get_response: Comparing irobotmcs with irobotmcs
2024-02-09 08:24:33,227 Thread-5   udi_interface      ERROR    roomba-poly:_get_response: Socket timeout while waiting for response
2024-02-09 08:24:34,244 Thread-5   udi_interface      INFO     roomba-poly:_get_response: Comparing irobotmcs with irobotmcs
2024-02-09 08:24:41,258 Thread-5   udi_interface      ERROR    roomba-poly:_get_response: Socket timeout while waiting for response
2024-02-09 08:24:42,265 Thread-5   udi_interface      INFO     roomba-poly:_get_response: Comparing irobotmcs with irobotmcs
2024-02-09 08:24:49,269 Thread-5   udi_interface      ERROR    roomba-poly:_get_response: Socket timeout while waiting for response
2024-02-09 08:24:50,273 Thread-5   udi_interface      INFO     roomba-poly:_get_response: Comparing irobotmcs with irobotmcs
2024-02-09 08:24:57,355 Thread-5   udi_interface      ERROR    roomba-poly:_get_response: Socket timeout while waiting for response
2024-02-09 08:24:58,371 Thread-5   udi_interface      ERROR    roomba-poly:discover: Failed to discover any Roomba robots
2024-02-09 08:24:58,372 Thread-5   udi_interface.custom INFO     custom:_save: Sending data customdata to Polyglot.
2024-02-09 08:24:58,373 Thread-5   udi_interface.custom INFO     custom:_save: Sending data notices to Polyglot.
2024-02-09 08:24:58,456 Thread-6   udi_interface      INFO     roomba-poly:handleRobotData: Loading saved robots {'robots': {}}
2024-02-09 08:24:58,458 Thread-6   udi_interface      INFO     roomba-poly:handleRobotData: We have restored the saved robot list
2024-02-09 08:24:58,461 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = customdata
2024-02-09 08:24:58,461 Thread-6   udi_interface      INFO     roomba-poly:handleRobotData: Finished with handleRobotData
2024-02-09 08:24:58,541 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = notices
2024-02-09 08:25:02,878 Thread-1   udi_interface      INFO     roomba-poly:addNodes: addNodes: Discovery fround 0 robots!
Solved by bpwwer
Update: there was a connectivity issue where a firewall rule was eating ICMP packets - put an allow rule in and things started working, thanks for putting me on the right track!
