KSaccullo01 Posted February 18, 2024 Posted February 18, 2024 When I reboot EISY HA does not see EISY. A "Failed to setup" error is thrown. Selecting reload fixes the problem, until the next reboot. The fix for me was to start VA from cron. /etc/rc.conf -- comment out vm_list="homeassistant" vm_enable="YES" vm_dir="zfs:HAIO" # vm_list="homeassistant" crontab. -- start the homeassistant vm 3 minutes after a reboot @reboot sleep 180 && vm start homeassistant I tried adding a delay vm delay in /etc/rc.conf. Did not work. vm_delay="300" hopes this helps someone else with the same problem
tazman Posted March 21, 2024 Posted March 21, 2024 @KSaccullo01I tried this fix but I'm unable to get it to work. Does it have to go somewhere special in the file? # /etc/crontab - root's crontab for FreeBSD # # $FreeBSD$ # SHELL=/bin/sh PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin # #minute hour mday month wday who command # # Save some entropy so that /dev/random can re-seed on boot. */11 * * * * operator /usr/libexec/save-entropy # # Rotate log files every hour, if necessary. 0 * * * * root newsyslog # # Perform daily/weekly/monthly maintenance. 1 3 * * * root periodic daily 15 4 * * 6 root periodic weekly 30 5 1 * * root periodic monthly # # Adjust the time zone if the CMOS clock keeps local time, as opposed to # UTC time. See adjkerntz(8) for details. 1,31 0-5 * * * root adjkerntz -a @reboot sleep 180 && vm start homeassistant
KSaccullo01 Posted March 27, 2024 Author Posted March 27, 2024 Did you hand edit crontab? it look like you are in the system crontab. to edit correctly enter: sudo crontab -e it will bring up the vi editor so you may want to familiarize yourself with vi first. The file will be be stored in /var/cron/tabs As a side note. I completely deleted the admin account and all traces of it. I created a new account that uses the root folder. Eliminated the need to enter sudo for my new account and activated the root account. When I created the original cron file I did so directly as root. It should not matter. Try sudo -s then crontab -e.
tazman Posted March 27, 2024 Posted March 27, 2024 0 16 minutes ago, KSaccullo01 said: Did you hand edit crontab? it look like you are in the system crontab. Yes I did edit it directly I guess that's why it did not work. I have it setup that after HA loads it restarts the ISY integration so I don't have to worry about it anymore but thanks for the info.
KSaccullo01 Posted March 28, 2024 Author Posted March 28, 2024 Try: sudo -s (enter password if prompted) crontab -e once saved new cron file should be in /var/cron/tabs/
