New Yolink outdoor temperature sensor displays F temps on device C temps in EISY
I realize that the Node developer is not responsible for Yolink issues, and this might be one. But, I got my new Yolink outdoor temperature sensor today and placed it about 1000 feet away in an orchard I never had real time monitoring in. Could not be happier.
In the YoLink app it displays temperatures in Farenheit, but in the plug in it displays temps in Centigrade. Nothing I can figure out changes anything.
Is there a way to make this consistently F?
Solved by auger66
I don't have any temperature sensors, but my leak detectors display the temperature in Farenheit on the admin console.
I assume in the node custom configuration parameters Key TEMP_UNIT has Value F, correct?
I have a Yolink temp sensor and it does display in F with the node server. However, the label in the admin console when you view the temp sensor node says Current Temp (C).
Edited by landolfi
Thanks Auger66 !! For my situation, that solved the problem. Made the change then did the reinstall etc and now so have F.
Edited by glacier991
