Cannot Enable Programs
I have not been able to get the Enable status of my programs to show ON. I have removed the migrated programs and replaced them with new code. I have reset the ISY and PLM and cleared the JAVA cache.
Regardless of what I have tried all I get in the Enabled Column is a "-" and the programs do not execute.
Hello Thartmann,
What version of the firmware are you running?
Michael,
I am runnining 2.4.15, but I was having the same issue with 2.4.13.
Tom Hartmann
Michel,
I can save new programs, however when they are saved they lose the enabled setting.
I have not yet worked through the steps to set-up my Linksys to enable the remote access.
Tom
Hello Tom,
Would you please do the following:
On the Program Summary Tab
1. Highlight all the rows, click on Disable, and then Apply
2. Highlight all the rows, click on Enable, and then Apply
Michel,
Tom
Michel,
I have tried the disable/enable, no change the programs remain with "-" in the enabled column.
Tom Hartmann
Mr. Hartmann,
Would you be kind enough to a) reset your userid/pwd to admin/admin and B) backup your ISY, and c) send your backup to tech@universal-devices.com?
I would sincerely appreciate it.
Michel,
Tom Hartmann
