Can't add Hue bulb to eisy. Has anyone been able to do this?
I have been trying to add a Hue bulb to my eisy.  I followed the directions found here https://www.universal-devices.com/nohub-hue/, but the bulb is not added.  I am running 5.8.3 on the eisy and my UD Mobile app is version 1.1.61.
When I try to add the bulb, which is powered on, using the app, I see a dialog box appear in the eisy console (see attachment) but that's as far as I get.  I cycled power to the bulb and tried again (several times) with the same result.  The bulb is right next to the eisy.  I do have the dongle attached and can control Z-wave devices without any issues.
Any ideas?
Solved by Javi
On 5/10/2024 at 10:00 AM, Javi said:
Try factory resetting the bulb from the hue app first.
This worked. Thank you!
On 5/10/2024 at 9:19 AM, drprm1 said:
Probably more predictable to use Hue Plugin with Hue hub...
I'm trying to get away from having multiple boxes control things.  I currently use the Hue hub for all my basement lights, but it's not very flexible.  The rest of the house is controlled by the eisy and Insteon.  I'm using incandescent bulbs with the Insteon devices and I'm trying to migrate to LED bulbs for the power saving.
