Techman Posted May 11 Share Posted May 11 @kzboray A while back you mentioned that your Insteon Hidden Door Sensors had a low battery node. My sensors show a Hearbeat node but no low battery node in the EISY with 5.8.3 firmware. My sensors are running v.45 and v.47 firmware. I'm aware that some versions off the sensor no longer support the heartbeat node. I'm curious what nodes you're seeing. I wonder if I delete and reinstall the sensor will the low battery node wil show up Quote Link to comment
kzboray Posted May 11 Share Posted May 11 @Techman Here's the info on the sensor I use and what it shows in AC. Hope that helps. Quote Link to comment
Techman Posted May 11 Author Share Posted May 11 Does your heartbeat node ever populate, or is its state always blank? Does your low battery node status show ON when the battery voltage is low? Quote Link to comment
kzboray Posted May 12 Share Posted May 12 @Techman The low battery works, but I've never seen the heartbeat populate with a value. 1 Quote Link to comment
Join the conversation
