PG3 Flume Water Plugin 3.1.0
The PG3 Plugin for Flume Water https://flumewater.com/ version 3.1.0 released.
If you are going to buy one, please use my affiliate link:  https://flumewater.com?grsf=0tbrt2
See the README for more information.
The Release Notes are also available.
Users of this plugin please comment on this issue if you have an opinion Consider adding 2 new variables to help with GPM Calculation either directly in Github (preferred) or on this post if you don't have a github account.
I can no longer use this device because my water company installed a fancy new meter that is not compatible, but I will continue supporting the best I can.  I still have the hub turned on to test, but can't see any water flow.
Edited by Jimbo.Automates
