Sprinkler Station Queued - False
Hello,  is it normal if I queue stations 1-3 manually for number 2 and 3 to show False on Station Queued?  For that matter, Station 1 is showing   as Status - Off. for what it is worth, he OpenSprinker Stations shows Stations queued 3
Not normal,  it may take a few seconds (short poll) for changes to be populated.
Are there any errors in the Node Servers Log?   Does the "Last Error Message" Property (status) fo the OpenSprinkler Controller node have any errors?  Did the IP address change (if it did be sure to setup an IP reservation so it will not do so again)?
Last error message was None, IP is reserved, and the Node server log only had entries from today.   That seems weird as that node says its uptime has been going for close to 2 weeks. So I ran the program (from Then), attached is the section where it started.
[redacted by UD]
Very odd, looks like the "Open Sprinkler Stations (Stations) node is being updated with the number of stations in queue but not the station itself.  Although it looks like the first station was triggered twice and is being counted twice.
Does this happen without using a program, try manually with a least 5 seconds (their apps refresh rate) between commands to as a test?
Sometimes Open sprinkler has odd behaviour if multiple commands are sent close together. If this only happens with a program please try adding waits between commands.
