Posted June 9, 20241 yr Sorry if this is a repeat question. So I setup my eisy from the IoX launcher. No issues. Then got a little curious because the eisy is advertised as having a direct desktop. I plugged in all the cable and started the box. I ended up at a terminal both before and after login. I'm familar with linux since the late 1980s but have never used FreeBSD. So what's the command to start the desktop?....and what's the command to add it to the start up programs? Thanks
