Support for sending commands to the DSC outputs
Hi @Goose66
I've been using Nodelink to interface to my alarm panel.  I noticed that ioguy's website is gone so I'm thinking it might be time to move on.  Does your NS allow for control of the output pins?  Based on what I read I don't think so but I wanted to confirm with you.
Thank you.
The DSC version of the EnvisaLink plugin does have output (command output) nodes, but this was never added to Evisalink-HW. IIRC it is because the EnvisaLink HW API didn’t support it, but I can look into it. If NodeLink was doing it, then it should be accessible.
I just notice that, while this was posted in the Envisalink-HW forum, the title of the topic "DSC outputs." If you do in fact have a DSC panel with an Envisalink, then the answer is yes, the command outputs will work. Here is the Envsialink-DSC forum: https://forum.universal-devices.com/forum/340-envisalink-dsc/.
If you have a Honeywell Vista panel instead, then I can add triggering outputs on and off in a future version. Whether or not I will be able to display the status of the output, though, is another question, and probably one I won't be able to determine (or add support for) because I do not have a relay board in my system.
