Unhandled Command?
This keeps showing up.  Pages in the logs.  ALl the same over and over.
2024-06-14 16:52:56,389 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 16:55:34,722 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 16:57:50,010 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 16:58:05,789 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 17:03:21,905 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 17:08:10,561 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 17:10:58,818 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 17:13:33,836 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 17:17:08,658 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 17:22:52,618 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 17:24:50,131 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 17:25:06,856 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 17:27:06,954 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 17:27:21,644 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 17:27:29,399 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 17:37:02,256 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 17:38:02,070 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 17:39:49,619 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 17:39:57,063 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 17:41:29,992 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 17:51:24,274 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 17:54:43,116 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 17:56:10,895 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 18:03:55,148 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 18:07:40,015 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 18:08:07,554 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 18:09:12,379 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 18:11:01,217 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 18:11:08,217 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 18:14:12,274 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 18:14:13,404 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 18:15:54,213 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 18:15:59,093 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 18:17:38,721 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 18:18:48,235 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 18:21:43,713 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 18:23:08,586 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 18:31:52,539 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
2024-06-14 18:35:58,470 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 18:36:07,595 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 18:38:41,943 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 18:40:19,017 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D5
2024-06-14 18:44:58,403 Thread-6277 (_command_listener) udi_interface      WARNING  nodes:process_command: Unhandled command received from EnvisaLink. Command: A0, Data: F700D9
Good news is everything I need from it is working and I can’t even tell what’s not working   I just was looking at logs for all nodesevers while working on something else with Benoit and noticed that
