landolfi Posted June 28 Share Posted June 28 I have an old Lamplinc 2457D2 that may have finally bought the farm. I try to reset it by holding the set button for as long as 30 seconds, but it does not beep, only flashes green until I unplug it. It is otherwise not responding to any Insteon commands. Is there any other way to bring this back? Quote Link to comment Share on other sites More sharing options...
kzboray Posted June 28 Share Posted June 28 @landolfi I believe you have to first remove power form the 2457. Here are the factory reset instructions for Insteon devices. https://www.insteon.com/support-knowledgebase/2016/2/24/factory-resetting-insteon-hub Quote Link to comment Share on other sites More sharing options...
landolfi Posted June 28 Author Share Posted June 28 Thanks, I tried that too. Still no luck. Quote Link to comment Share on other sites More sharing options...
kzboray Posted June 28 Share Posted June 28 Sounds like it's no longer operating correctly. https://shop.insteon.com/products/dimmer-module Quote Link to comment Share on other sites More sharing options...
landolfi Posted June 28 Author Share Posted June 28 Thanks! I swapped it for a Zwave plug. I still have one Lamplinc working reliably, and when that goes it will likely be pure Zwave and Zigbee for me with the possible exception of my light sensor/IOLinc combination. Quote Link to comment Share on other sites More sharing options...
Join the conversation
