3.1.9 in Beta
This beta completes the communications with Ratgdo in and out as well as the docs.
The Bonjour resolution for the Ratgdo is working consistently but can take a really long time on start-up the odd time.  Feel free to use it or put in the IP number for your ratgdo config label.
Finally, a small fix on the switch node from 3 months ago returns On/Off messaging.  I also did this as a hot fix for the production version.  For old installations it meant some switches will be True/False and some On/Off.  Unfortunately to fix, the node (NOT the whole plugin) needs to be deleted and regenerated.  The complete procedure is in this thread:
I will let this run for a number of days and move to production.
FEEDBACK IS WELCOME!
VERSION = '3.1.9'
3.1.9
DONE Garage device read status directly from Ratgdo through ESPHome RESTapi
DONE update docs for garage Ratgdo integration
FIX switch st uom from 2 True/False to 25 On/Off
TODO Bonjour discovery is sometimes slow
3.1.8
DONE Garage device sends commands directly to Ratgdo through ESPHome RESTapi
DONE Bonjour discovery of Ratgdo garage device
3.1.7
DONE Small refactors
DONE redo environment
3.1.6
FIX better solution to markdown2 issue
3.1.5
FIX repair docs due to markdown2 issue
3.1.4
DONE docs updated for garage
3.1.3
DONE: new device 'garage' door (update to/from variables option)
3.1.2
DONE: ISY name changes based on updates to config / YAML / JSON
3.1.1
DONE: YAML file option for configuration
DONE: JSON option for web based configuration
DONE: Discover button to update based on config updates
3.1.0
DONE: move version history out of README to own file
DONE: update docs
3.0.1
DONE fix get value from variable
3.0.0
DONE add control ability to contact device
DONE refactored to modern template
previous updates:
see versionHistory.md
