majkman Posted July 22 Share Posted July 22 I moved from the trial to purchased plugin. I am on 3.1.1 this message appears: The subscription for this node server has expired I have deleted and reinstalled the node server into the same slot. Available purchase/install options Version Price Purchase Install Type Installed 3.1.1 Free Trial Free /per 1 month Install ZIP package 3.1.1 Free Perpetual Free Install ZIP package Slot 11 Is this a bug or is there a workaround? Thank you Quote Link to comment
Geddy Posted July 22 Share Posted July 22 @majkman what version of PG3x are you running? Are you on Polisy or eisy? If on Polisy you might need to upgrade to PG3x if you haven't. Details on that can be found in the wiki. If you're on eisy make sure it's updated. Current version should be 3.2.27. If you're not there then you should update. Last option would be attempt to install in a different slot and see if that works. Quote Link to comment
majkman Posted July 22 Author Share Posted July 22 eisy, PG3x version 3.2.27, IoX version 5.8.3 I will try another slot Quote Link to comment
majkman Posted July 22 Author Share Posted July 22 (edited) Moved from slot 11 to 14, same message: The subscription for this node server has expired I am going to guess this is a code bug that JimBo will have to look at. Edited July 24 by majkman Quote Link to comment
vspete Posted July 23 Share Posted July 23 I just restarted the Flumewater NodeServer with a perpetual license and now receive the "subscription for this node server has expired" message. The nodeserver has been running flawlessly for months. I am on an a eISY running PG3X v3.2.27 / IoX v5.8.4. Hopefully, JimBo can remedy this situation. Quote Link to comment
Jimbo.Automates Posted August 1 Share Posted August 1 Sorry guys, I never saw this post, not sure why I didn't get a notification. I can't do anything about licenses, we'll need assistance from @bmercier 1 Quote Link to comment
vspete Posted August 1 Share Posted August 1 Hi Jim, thanks for the response. Good to know who works licensing issues. This is the first issue with licensing I have encountered. Will be nice to get your NodeServer back. Cheers! Quote Link to comment
bmercier Posted August 2 Share Posted August 2 On 8/1/2024 at 1:48 PM, vspete said: Hi Jim, thanks for the response. Good to know who works licensing issues. This is the first issue with licensing I have encountered. Will be nice to get your NodeServer back. Cheers! Please open a ticket, I will investigate the license issue. Please include your uuid & a link to this thread. Quote Link to comment
majkman Posted August 2 Author Share Posted August 2 I have opened ticket #25030 Thank you Gary Quote Link to comment
vspete Posted August 2 Share Posted August 2 I have opened ticket #25032 Thank you, Pete Quote Link to comment
Jimbo.Automates Posted August 2 Share Posted August 2 @majkman and @vspete, Please try to restart the plugin. With @bmercier assistance I made some changes to the store database. Let me know if that fixes it. Quote Link to comment
bmercier Posted August 2 Share Posted August 2 12 minutes ago, Jimbo.Automates said: @majkman and @vspete, Please try to restart the plugin. With @bmercier assistance I made some changes to the store database. Let me know if that fixes it. First, please go to the Plugin store and click on "Refresh Store". Then, you can try to restart the plugin. If it has been reinstalled in an attempt to fix it, it should be reinstalled again as the installed edition will be "Free", instead of "Standard" as it should. 2 Quote Link to comment
majkman Posted August 2 Author Share Posted August 2 I refreshed the store It seems to have been solved, the Plugin is running now. I am not sure what you mean by free/standard? I reinstalled the standard and it seems to be working. I enclosed the purchase options. Thank you!!!! 1 Quote Link to comment
vspete Posted August 2 Share Posted August 2 (edited) 14 minutes ago, bmercier said: it should be reinstalled again as the installed edition will be "Free", instead of "Standard" as it should. Performed the reinstall as directed. Version shows to be "Free" and License shows to be "Perpetuall". After reinstall, I restarted the plug-in. After running for 60 seconds, the plug-in disconnects and reports an expired license as it has done since this issue started. After reading Gary's post I did it again (this time refreshing the store). This allowed me to choose a "Standard" rather than "Free" version to re-install. This did the trick and the plug-in is now running correctly. Thanks.... Edited August 2 by vspete 1 Quote Link to comment
Jimbo.Automates Posted August 2 Share Posted August 2 Great, sorry for the trouble, and thanks to @bmercier for figuring it out. 1 Quote Link to comment
