Appending my ISY IP log-in address
I read somewhere that I can simply "append" my IP log-in address (with /admin) to expedidte logging in and opening the Admin Console. Just where in the ISY99 software would I "append" this so that it is saved as such?
Terry
Hi Terry,
You would not change anything in the ISY.
7. IMPORTANT Once upgrade is completed and ISY reboots, use any of the following methods to access your ISY's Admin Console:
a. http://isy/admin - applet (Windows only)
b. http://isy/admin.jnlp - Java application (Windows only)
c. http://your.isy.ip.address/admin - applet
d. http://your.isy.ip.address/admin.jnlp - Java application
e. http://www.universal-devices.com/99i - applet
f. http://www.universal-devices.com/99i/admin.jnlp - Java application
Any of these links will bring you to the Admin Console. Then you can add a bookmark to your browser. Using any of the links which reference jnlp (Java application) should add an icon to your desktop which will bypass any browser.
Rand
Terry
