Select Command Action
Got the update and everything works great as far as using Yolink to replace my Insteon motion sensors.
i have noticed that if the nodeserver restarts for any reason the command actions associated with each device reverts back to ON/OFF.
I have to go through all and reset to DON, which is what I need out of it.
Would like to see this changes so they don’t reset everytime.
Thanks Panda!
Solved by Panda88
i looked at it before.  did not find an easy solution.  it has been a while so it may be possible but it will take some time
i usually handle this by running a special program on boot of ISY
