Support of Kasa EP25 and others requiring authentication
Hi, hoping to use this plugin with my Kasa EP25 devices. According to the Github info, it is the intent to support any devices in the python-kasa library. That library lists the EP25 but with an asterisk saying new devices need authentication. Do you plan to support that? Currently it just responds with
ERROR Controller:_add_manual_devices: Unsupported device 192.168.3.118:
Thanks, Andy
Also getting "Unsupported device" with a new HS220 I tried to add today (hardware version 3.26, firmware 1.1.1).  No issues with older HS220's running 3.0/1.0.11.
  • 2 months later...
Any news here?  I have a new HS220 3.26 hardware version and firmware 1.1.1 and it is not being discovered either.  Is the Home Assistant integration from TP-Link itself?  Or is it unofficial like this plugin?  I ask because this new device does work in HA.
Edited by btreinders
So I bought some HS200 switches hardware version 5.26 and firmware 1.0.1 and I did not let it update and it isn't being discovered either.  I tried putting in the IP as well.  Appreciate any answers.
  • 1 month later...
I installed 3.2.24. The node server created a node which is visible in the admin console and shows connected.
No devices were discovered. I added a secondary discover network broadcast address for the IOT network (which I can ping no problem - no blocking). Still no discovery. I manually added the IP address of a kasa EP25. Restarted everything including rebooting the EISY. Still no device. Turned on debug logging. Did not expect anything on the 3.* network, the devices are on the 11.* network - and the manual discovery got an "unexpected keyword argument 'address' trying to connect"
2025-01-11 06:48:10.377 Thread-9 (handler_start) udi_interface INFO Controller:discover: enter: 192.168.3.255
2025-01-11 06:48:10.377 Thread-10 (run_forever) udi_interface DEBUG Controller:_discover: enter: target=192.168.3.255
2025-01-11 06:48:10.378 Thread-10 (run_forever) kasa.discover DEBUG discover:do_discover: [DISCOVERY] 192.168.3.255 >> {'system': {'get_sysinfo': {}}}
2025-01-11 06:48:10.516 Thread-10 (run_forever) kasa.discover DEBUG discover:discover: Waiting 5 seconds for responses...
2025-01-11 06:48:15.566 Thread-10 (run_forever) kasa.discover DEBUG discover:discover: Discovered 0 devices
2025-01-11 06:48:15.566 Thread-10 (run_forever) udi_interface INFO Controller:_discover: Discover.discover(192.168.3.255) done: checking for previously known devices
2025-01-11 06:48:15.566 Thread-10 (run_forever) udi_interface DEBUG Controller:_discover: exit
2025-01-11 06:48:15.566 Thread-9 (handler_start) udi_interface DEBUG Controller:discover: result=None
2025-01-11 06:48:15.567 Thread-9 (handler_start) udi_interface INFO Controller:discover: calling: _discover(target=192.168.11.255)
2025-01-11 06:48:15.567 Thread-10 (run_forever) udi_interface DEBUG Controller:_discover: enter: target=192.168.11.255
2025-01-11 06:48:15.567 Thread-10 (run_forever) kasa.discover DEBUG discover:do_discover: [DISCOVERY] 192.168.11.255 >> {'system': {'get_sysinfo': {}}}
2025-01-11 06:48:15.568 Thread-10 (run_forever) kasa.discover DEBUG discover:discover: Waiting 5 seconds for responses...
2025-01-11 06:48:20.619 Thread-10 (run_forever) kasa.discover DEBUG discover:discover: Discovered 0 devices
2025-01-11 06:48:20.619 Thread-10 (run_forever) udi_interface INFO Controller:_discover: Discover.discover(192.168.11.255) done: checking for previously known devices
2025-01-11 06:48:20.619 Thread-10 (run_forever) udi_interface DEBUG Controller:_discover: exit
2025-01-11 06:48:20.619 Thread-9 (handler_start) udi_interface DEBUG Controller:discover: result=None
2025-01-11 06:48:20.619 Thread-9 (handler_start) udi_interface INFO Controller:discover: exit
2025-01-11 06:48:20.620 Thread-10 (run_forever) udi_interface INFO Controller:_add_manual_devices: Adding manual device 192.168.11.175
2025-01-11 06:48:20.620 Thread-10 (run_forever) udi_interface ERROR Controller:_add_manual_devices: Controller.discover_single() got an unexpected keyword argument 'address' trying to connect to 192.168.11.175
2025-01-11 06:48:20.620 Thread-10 (run_forever) udi_interface INFO Controller:_add_manual_devices: Adding manual device 192.168.11.179
2025-01-11 06:48:20.620 Thread-10 (run_forever) udi_interface ERROR Controller:_add_manual_devices: Controller.discover_single() got an unexpected keyword argument 'address' trying to connect to 192.168.11.179
2025-01-11 06:48:20.620 Thread-9 (handler_start) udi_interface DEBUG Controller:add_manual_devices: result=None
2025-01-11 06:48:20.620 Thread-9 (handler_start) udi_interface INFO Controller:add_manual_devices: exit
2025-01-11 06:48:20.620 Thread-9 (handler_start) udi_interface INFO Controller:handler_start: exit Kasa Controller
Edited by Jimbo.Automates
Discovery does not use ping, it sends UDP packets, which do not cross subnet boundaries.  There is a discussion about this on the python-kasa issues https://github.com/python-kasa/python-kasa/issues/1431
I'll look into that error.  Issue created https://github.com/UniversalDevicesInc-PG3/udi-poly-kasa/issues/23
