SHM Posted October 18, 2024 Posted October 18, 2024 Have been using my 2.5i ratgdo with plugin 4.08 without issues. Just tried OTA update to firmware 2.59 (from 2.57) and lost connection with the device. I tried re-installing (with Chrome) the ESPHome firmware but no connection results when using “dry contact” and “2.5i” selections. Interestingly, the ESPHome will re-install if I select the security 2.0, but the garage door does not open or close when commanded (ratgdo home screen attached) Any suggestions? Quote
gzahar Posted October 18, 2024 Posted October 18, 2024 Try connecting directly to PC and erase all data when loading firmware. Quote
SHM Posted October 18, 2024 Author Posted October 18, 2024 Have already done that with no successs Quote
hart2hart Posted October 18, 2024 Posted October 18, 2024 The latest version of the node server is for ESPHome based ratgdo firmware. Is 2.59 ratgdo firmware only for the mqtt version? Which would break its connection with the node server. Quote
SHM Posted October 21, 2024 Author Posted October 21, 2024 Was able to regain ability to "visit" Ratgdo after several rounds of re-flashing the device, which is a 25i running "dry contact" protocol. Unfortunately, the open/close commands in the AC or in UD mobile do not open/close door. The "toggle" command in the AC does, but the correct door status is not updated. Not sure why this has happened as I have had a very stable system. Attaching log package. ratgdo_10-21-2024_81022_AM.zipFetching info... Quote
Solution SHM Posted October 22, 2024 Author Solution Posted October 22, 2024 Problem solved. I had a loose "open sensor" wire. Now all works well. Per Paul Weiland, firmware 2.59 is only for MQTT. Quote
