Something wrong with Outlet interface?
I have added a bunch of leak sensors and motion sensors to my yolink hub and everything works as expected and updates in the Admin console. However, the Yolink Outlet gets added as a node, but doesn't update status in either direction. Any idea what is wrong? I did try removing and readding the device several times. Also restarted the node server and admin console. As I mentioned the other devices update correctly.
PG3x Version 3.2.27
Status: Connected
Frontend Version: 3.2.27
IoX Version: 5.8.4
Current Version: 1.2.3
This is the debug log when I manually turn the switch on and off
2024-10-25 16:43:04.049 paho-mqtt-client-7f9440f690b24b919c0f5f4b752713c0 udi_interface DEBUG yoLink_init_V3:on_message: on_message: {'event': 'Outlet.StatusChange', 'time': 1729888984014, 'msgid': '1729888984013', 'data': {'state': 'closed', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -35, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'}
2024-10-25 16:43:04.049 paho-mqtt-client-7f9440f690b24b919c0f5f4b752713c0 udi_interface DEBUG yoLink_init_V3:on_message: Message received and put in queue (size : 1)
2024-10-25 16:43:04.049 paho-mqtt-client-7f9440f690b24b919c0f5f4b752713c0 udi_interface DEBUG yoLink_init_V3:on_message: Creating threads to handle the received messages
2024-10-25 16:43:04.050 Thread-265 (process_message) udi_interface DEBUG yoLink_init_V3:process_message: Received message - Q size=0
2024-10-25 16:43:04.050 paho-mqtt-client-7f9440f690b24b919c0f5f4b752713c0 udi_interface DEBUG yoLink_init_V3:on_message: 1 on_message threads starting
2024-10-25 16:43:04.050 Thread-265 (process_message) udi_interface DEBUG yoLink_init_V3:process_message: process_message : {'event': 'Outlet.StatusChange', 'time': 1729888984014, 'msgid': '1729888984013', 'data': {'state': 'closed', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -35, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'}
2024-10-25 16:43:04.050 Thread-265 (process_message) udi_interface DEBUG yoLink_init_V3:process_message: process_message for d88b4c0100093b37: {'event': 'Outlet.StatusChange', 'time': 1729888984014, 'msgid': '1729888984013', 'data': {'state': 'closed', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -35, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'} yl-home/7f9440f690b24b919c0f5f4b752713c0/d88b4c0100093b37/report
2024-10-25 16:43:04.050 Thread-265 (process_message) udi_interface DEBUG yoLink_init_V3:process_message: porcessing report: {'event': 'Outlet.StatusChange', 'time': 1729888984014, 'msgid': '1729888984013', 'data': {'state': 'closed', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -35, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'}
2024-10-25 16:43:04.050 Thread-265 (process_message) udi_interface INFO udiYoOutletV2:updateStatus: udiYoOutlet updateStatus
2024-10-25 16:43:04.050 Thread-265 (process_message) udi_interface DEBUG yolink_mqtt_classV3:updateCallbackStatus: Outlet - updateCallbackStatus : {'event': 'Outlet.StatusChange', 'time': 1729888984014, 'msgid': '1729888984013', 'data': {'state': 'closed', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -35, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'}
2024-10-25 16:43:04.050 Thread-265 (process_message) udi_interface DEBUG yolink_mqtt_classV3:updateStatusData: Outlet - updateStatusData : {'event': 'Outlet.StatusChange', 'time': 1729888984014, 'msgid': '1729888984013', 'data': {'state': 'closed', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -35, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'}
2024-10-25 16:43:04.051 Thread-265 (process_message) udi_interface INFO udiYoOutletV2:updateData: udiYoOutlet updateData - schedule 0
2024-10-25 16:43:04.051 Thread-265 (process_message) udi_interface.node DEBUG node:setDriver: 8b4c0100093b37:Plug 1 No change in ST's value
2024-10-25 16:43:04.051 Thread-265 (process_message) udi_interface DEBUG yolinkOutletV2:getState: Outlet - getState :{'lastUpdTime': 1729888984014, 'lastMessage': {'event': 'Outlet.StatusChange', 'time': 1729888984014, 'msgid': '1729888984013', 'data': {'state': 'closed', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -35, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'}, 'lastStateTime': 1729888984014, 'online': True, 'data': {'state': {'state': 'closed', 'power': 0, 'watt': 0, 'version': '0433', 'time': '2024-10-25T20:31:45.000Z', 'tz': 0, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -35, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}, 'delay': {'ch': 1, 'on': 0, 'off': 0}, 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}}, 'schedules': {'supportSeconds': True}}}
2024-10-25 16:43:04.051 Thread-265 (process_message) udi_interface DEBUG yolinkOutletV2:getState: Outlet - getState online
2024-10-25 16:43:04.051 Thread-265 (process_message) udi_interface DEBUG yolinkOutletV2:getState: Outlet - getState data {'state': {'state': 'closed', 'power': 0, 'watt': 0, 'version': '0433', 'time': '2024-10-25T20:31:45.000Z', 'tz': 0, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -35, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}, 'delay': {'ch': 1, 'on': 0, 'off': 0}, 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}}, 'schedules': {'supportSeconds': True}}
2024-10-25 16:43:04.051 Thread-265 (process_message) udi_interface DEBUG yolinkOutletV2:getState: Outlet - getState - return Unknown
2024-10-25 16:43:04.051 Thread-265 (process_message) udi_interface.node DEBUG node:setDriver: 8b4c0100093b37:Plug 1 No change in GV20's value
2024-10-25 16:43:11.692 paho-mqtt-client-7f9440f690b24b919c0f5f4b752713c0 udi_interface DEBUG yoLink_init_V3:on_message: on_message: {'event': 'Outlet.StatusChange', 'time': 1729888991656, 'msgid': '1729888991656', 'data': {'state': 'open', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -40, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'}
2024-10-25 16:43:11.692 paho-mqtt-client-7f9440f690b24b919c0f5f4b752713c0 udi_interface DEBUG yoLink_init_V3:on_message: Message received and put in queue (size : 1)
2024-10-25 16:43:11.692 paho-mqtt-client-7f9440f690b24b919c0f5f4b752713c0 udi_interface DEBUG yoLink_init_V3:on_message: Creating threads to handle the received messages
2024-10-25 16:43:11.692 Thread-266 (process_message) udi_interface DEBUG yoLink_init_V3:process_message: Received message - Q size=0
2024-10-25 16:43:11.692 paho-mqtt-client-7f9440f690b24b919c0f5f4b752713c0 udi_interface DEBUG yoLink_init_V3:on_message: 1 on_message threads starting
2024-10-25 16:43:11.692 Thread-266 (process_message) udi_interface DEBUG yoLink_init_V3:process_message: process_message : {'event': 'Outlet.StatusChange', 'time': 1729888991656, 'msgid': '1729888991656', 'data': {'state': 'open', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -40, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'}
2024-10-25 16:43:11.693 Thread-266 (process_message) udi_interface DEBUG yoLink_init_V3:process_message: process_message for d88b4c0100093b37: {'event': 'Outlet.StatusChange', 'time': 1729888991656, 'msgid': '1729888991656', 'data': {'state': 'open', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -40, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'} yl-home/7f9440f690b24b919c0f5f4b752713c0/d88b4c0100093b37/report
2024-10-25 16:43:11.693 Thread-266 (process_message) udi_interface DEBUG yoLink_init_V3:process_message: porcessing report: {'event': 'Outlet.StatusChange', 'time': 1729888991656, 'msgid': '1729888991656', 'data': {'state': 'open', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -40, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'}
2024-10-25 16:43:11.693 Thread-266 (process_message) udi_interface INFO udiYoOutletV2:updateStatus: udiYoOutlet updateStatus
2024-10-25 16:43:11.693 Thread-266 (process_message) udi_interface DEBUG yolink_mqtt_classV3:updateCallbackStatus: Outlet - updateCallbackStatus : {'event': 'Outlet.StatusChange', 'time': 1729888991656, 'msgid': '1729888991656', 'data': {'state': 'open', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -40, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'}
2024-10-25 16:43:11.693 Thread-266 (process_message) udi_interface DEBUG yolink_mqtt_classV3:updateStatusData: Outlet - updateStatusData : {'event': 'Outlet.StatusChange', 'time': 1729888991656, 'msgid': '1729888991656', 'data': {'state': 'open', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -40, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'}
2024-10-25 16:43:11.693 Thread-266 (process_message) udi_interface INFO udiYoOutletV2:updateData: udiYoOutlet updateData - schedule 0
2024-10-25 16:43:11.693 Thread-266 (process_message) udi_interface.node DEBUG node:setDriver: 8b4c0100093b37:Plug 1 No change in ST's value
2024-10-25 16:43:11.693 Thread-266 (process_message) udi_interface DEBUG yolinkOutletV2:getState: Outlet - getState :{'lastUpdTime': 1729888991656, 'lastMessage': {'event': 'Outlet.StatusChange', 'time': 1729888991656, 'msgid': '1729888991656', 'data': {'state': 'open', 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -40, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}}, 'deviceId': 'd88b4c0100093b37'}, 'lastStateTime': 1729888991656, 'online': True, 'data': {'state': {'state': 'open', 'power': 0, 'watt': 0, 'version': '0433', 'time': '2024-10-25T20:31:45.000Z', 'tz': 0, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -40, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}, 'delay': {'ch': 1, 'on': 0, 'off': 0}, 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}}, 'schedules': {'supportSeconds': True}}}
2024-10-25 16:43:11.693 Thread-266 (process_message) udi_interface DEBUG yolinkOutletV2:getState: Outlet - getState online
2024-10-25 16:43:11.693 Thread-266 (process_message) udi_interface DEBUG yolinkOutletV2:getState: Outlet - getState data {'state': {'state': 'open', 'power': 0, 'watt': 0, 'version': '0433', 'time': '2024-10-25T20:31:45.000Z', 'tz': 0, 'loraInfo': {'netId': '010204', 'devNetType': 'C', 'signal': -40, 'gatewayId': 'd88b4c160305f2f4', 'gateways': 2}, 'delay': {'ch': 1, 'on': 0, 'off': 0}, 'alertType': {'overload': False, 'highLoad': False, 'lowLoad': False, 'highTemperature': False, 'remind': False}}, 'schedules': {'supportSeconds': True}}
2024-10-25 16:43:11.693 Thread-266 (process_message) udi_interface DEBUG yolinkOutletV2:getState: Outlet - getState - return Unknown
2024-10-25 16:43:11.694 Thread-266 (process_message) udi_interface.node DEBUG node:setDriver: 8b4c0100093b37:Plug 1 No change in GV20's value
Solved by Panda88
Ok, so about an hour later I went to the mobile UD app and it allowed me to switch the outlet on and off. Then I tried the admin console again and it had started to work. So, I did go ahead and install 1.2.5, and that works, but it is not clear to me if somehow the interface had managed to repair itself at some point before I did that. And not sure what bug you found, but I am grateful for the quick response!
It was a bug in reporting - control updated the state automatically - It is only when something else controls the outlet this happens (i.e. someone presses the local button)
