Hue plug
so I added a hue plug to my hue system, works fine. Problem is how to get it to eisy. My existing hue lights all in eisy and work fine, just plug wont show. I tried adding node, adding all nodes, restarting eisy, restarting hue, no joy. Im sure this is easy, just escaping me
@grossmd moved into the Hue Plugin area. I'm assuming you're using the Hue Plugin for the lights. I'm not entirely sure if the plugin is designs to support the outlets.
The Plugin was developed several years ago and then migrated to PG3, but don't think the underlying code was updated at that time.
Do you have the Z-Matter dongle? I wonder if you could attempt a direct connect through Zigbee for the outlet. I know the lights are able to be connected that way (though I haven't tried it yet).
