Blue Iris Node Server Disconnected after Software update
oops...I spoke too soon. I had not disabled by program that does a rediscover when a disconnect occurs. Just did test again and this time no automatic reconnect occurred. Still need to do a rediscover
  • 9 months later...
Is there anything further on this?  Every time there is any hiccup in my network Blue Iris disconnects (despite saying "connected").  It seems that people are saying using the "re-discover" button will fix it.  Do I need to just have a program that runs every hour triggering a "re-discover"?
  • 2 months later...
@bpwwer
I am still having issues with every time blue iris server restarts or otherwise goes down and then comes back online, the node server looses its connection and I have to manually restart it. I am not clear on if this has a programmatic solution or how to manage it.
This is how I handle it:
'Blue Iris' Server Status is Disconnected
Or 'Blue Iris' Server Status is Red
Send Notification to 'Gary' content 'Blue Iris Disconnected'
Wait 1 minute
Set 'Blue Iris' Re-Discover
Followed by a second program:
'Blue Iris' Server Status is Green
Wait 1 minute
Send Notification to 'Gary' content 'Blue Iris Node Server Reconnected'
  • 3 weeks later...
The above program isn't working for me. I just updated packages and I had the above program set to run at startup. It didn't run true because the server status was unpopulated, not red. I can probably fix the not running at startup by switching to "is not green" instead of "is red". Unfortunately I didn't remember to wait a whole minute for the re-discover to see if that worked. I ended up restarting the node manually.
Sorry to hear it is not working for you. I found that I needed the 1 minute wait because a number of my disconnects occurred when the computer running blue iris did an automatic windows update. This 1 minute delay gave the computer time to reboot and restart blue iris allowing the rediscover command time to see blue iris
I set it to run at startup and changed "is red" to "is not green". I have since reboot eisy twice and both times it connected, so I believe that solved the issue.
