Scene not working properly
Hi, hoping I can get some assistance with debugging a scene I have setup. I have attached a screenshot.
Although I have setup the scene with various on levels as indicated in the action column, when I activate the scene using the Remote button all the lights come on at 100%. I assume I am missing something, but not sure what. Assistance appreciated.
Mark
Solved by tazman
In your picture you are not showing the left column where you have to select your "Remote button" then select what happens with all the devices in your scene whe that activates the scene.
Thanks! I was highlighting the scene name, rather than the controller.  This worked when I highlighted the controller and adjusted the scene parameters.
