IRLinc to
I am having trouble getting an IRLinc Command to trigger a program. I have a few lights linked to IRLinc, when the IRLinc is triggered the scene executes as it should but the program never runs.
The program I have a program setup should clean up some Keypad Linc switch statuses. I can not get the the program to run.
Control 'Utility / IRLinc.09 TV Mode' is switched On
Set Scene 'Living Room / Keypad Scenes / Fan Keypad B Normal' Off
Set Scene 'Living Room / Keypad Scenes / Front Porch B Normal' Off
Am I doing something wrong?
Should this scene run when the IRlinc scene is triggered?
Is there a better way to achieve what I want?
Thanks for any help
  • 1 month later...
Did you get this working?
Since your controlling two Scenes it makes since to use a program, and your program looks fine.
Are you seeing the status of the 'Utility / IRLinc.09 TV Mode' node toggle ok?
Do you have this node in toggle mode or non toggle mode?
If in non toggle mode is it setup to send the on?
