What are hints
What are hints for in the device dashboard? It's down in the info section Example: Hint 0.0.0.112
Hint is used by some User Interfaces (Mobilink) or Services (i.e. Alexa)  to display the Node as a certain type (like a thermostat).  UD Mobile will use Hints (lower priority) or UD Mobile's Device Type (Higher Priority, in the menu of the Node on the Home Tab) to show a node with a custom tile (like thermostats).
