Polisy LAN address not working in IOX finder
Just upgraded to Mac OS 15 on a new laptop.  When I start jnlp to access the polisy, only the WAN works.  If I type in the polisy LAN address (https://LAN:8443/desc), the UUID appears but no firmware version and nothing happens when I try to load the AC from here.  Entering the polisy LAN in a browser also does not open anything.  I have cleared the Java cache and rebooted the polisy and IOX.  Seems like something is blocking the LAN access.  Suggestions?
Solved by dbwarner5
try typing this into a web browser... http://<LAN IP>:8080/admin.jnlp
this should download a local copy of admin.jnlp which will link to the AC and will give you direct access to the sign in screen.
Otherwise, try adding http://<LAN IP>:8080 to the UD Finder and see if it finds it locally.
The first worked!  Thanks
