How does the ISY Check programs?
ketchup318
Hi
I have a program that checks to see if the garage door is opened, and if it's past sunset, it turns on the light. While writing the code, I stumbled across an interesting question. When does the ISY check the condition of a program? For instance, in the following code (paraphrasing code)
IF
After sunset and before sunrise
AND status garage door is ON
THEN
does the ISY check the program every second? That seems a bit inefficient. Is it better to write the code like the following
IF
AND after sunset and before sunrise
THEN
Is this more efficient since the code is only checked when the garage door status has changed?
Practically there is no difference.
The program will run when the status of the door changes. Then it will check the time constraint.
You could put the program in a folder with the Schedule Condition on the folder which will disable the program outside of the hours you want.
But it only takes a few clock cycles either way.
      38k
      379.6k
