994 to EISY Migration fails
Question, If you are migrating from 994 (Pro / Zwave) with serial PLM to EISY with USB PLM, should it work ?
I have tried 3 times, each time none of the Insteon device are accessible ...
Following the guide, Restore 994 backup using 994 backup
reboot
See all Insteon & Zwave devices, but nothing works
reboot, EISY starts discovering all Zwave devices
reboot
Zwave devices are responding, Insteon devices report Not Responding
Restore PLM, runs for HOURS and hours, Event Viewer ONLY shows PLM reset when PLM restore started
I've put the 994 back in service and everything is working
Solved by Techman
Being that you're using a new/different PLM on your EISY you need to exactly follow the replace PLM guidelines for your EISY. See attached
The reason nothing is working is because your EISY is currently programmed with the serial PLM and doesn't yet reconize the USB PLM
Replace PLM Procedure (EISY or POLISY).pdf
Thank you, that was my suspicion...
Again the [Eisy:User Guide] has failed to identify this twist in their migration procedure
