Reboot needed to access Polyglot 3x and Wrong Uptime on Page
Just had what seems to issue others have hit where they could not login to the Polyglot 3x web page at https://192.168.1.53:3000/dashboard - was getting error 503 as if my pass was bad / tried resetting via admin consul but no effect
after searching on how to gracefully restart eisy to no avail I yanked power for 15 seconds then plugged in again  (some easier answer maybe ?)  ..
Good news is that after 2 mins I could login again with my credentials of admin/admin . (same I had been using 2 weeks ago last I started testing out my new eisy) ..
Interesting news is that my portal page shows uptime of roughly last time I was using eisy / kinda expected to see this at 2 mins vs 2 weeks since the eisy was just unplugged for 15 seconds ..
ah ok so I figured out that the "up time" is purely a java counter so that pulled from my browser cache after restart // even though I had closed browser and thought I cleared cache .. but this cleared after a few page navigations on the PG3 / now shows correct uptime of 21 mins ..
Would still be nice to post proper way to restart PG3 when you cannot login / or is yanking power really best way ???
Also .. next newbie Q, please.. how to set proper time in PG3 (the log files are all 2 hours off) was the ISY had been due to default time zone which I change 10mins back .. however seems updating time zone (time offset) in ISY does not flow over to PG3 ?
thx
On eisy 5 button presses reboots the device and 6 button presses shuts down the unit where the light will turn red and you can safely unplug the unit or press the button again to restart.
